Jonathan Pounsett Posted August 5, 2021 Share Posted August 5, 2021 I can’t believe I’ve lost so many parts! The latest things I’ve mislaid and need to replace; ~ Fuel tank filler neck grommet. ~ Flexible heating & ventilating ducts. 🤞 1 Link to comment Share on other sites More sharing options...
Ems Posted August 5, 2021 Share Posted August 5, 2021 You can get the filler neck rubber from Edelschmiede 1 Link to comment Share on other sites More sharing options...
Snowy Posted August 6, 2021 Share Posted August 6, 2021 16 hours ago, Jonathan Pounsett said: I can’t believe I’ve lost so many parts! The latest things I’ve mislaid and need to replace; ~ Fuel tank filler neck grommet. ~ Flexible heating & ventilating ducts. 🤞 I have boxes of the vent ducts. Assuming you mean the ones behind the dash. 1 Link to comment Share on other sites More sharing options...
mantasrme Posted August 6, 2021 Share Posted August 6, 2021 Hatch or coupe fuel neck rubber? i may have one. I also have a load of all the heater duct pipes, which ones are you after 1 Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted August 6, 2021 Author Share Posted August 6, 2021 28 minutes ago, Snowy said: I have boxes of the vent ducts. Assuming you mean the ones behind the dash. I’ll take a photo of the ducts I’m after. 23 minutes ago, mantasrme said: Hatch or coupe fuel neck rubber? i may have one. I also have a load of all the heater duct pipes, which ones are you after It’s a Coupe. Thanks @Snowy @mantasrme Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted August 6, 2021 Author Share Posted August 6, 2021 These are the bits I’ve got - I can’t find the square 90 degree bends and I’m not sure what’s else is missing. The longer flexi hose at the bottom has been eaten by mice so I need that one and the windscreen diffuser (top right and separate photo) is damaged so could do with that too. Thanks guys 🙂 Link to comment Share on other sites More sharing options...
mantasrme Posted August 6, 2021 Share Posted August 6, 2021 I can do you the 2 that go up to the dash vents from the sides of the heater box, the long round tube and a used fuel tank grommet (little bt of overspray but will clean up) i don't have any spare dash vents, but yours actually look good in the photo. Mostly they have one end broken where the bolts hold them on 1 Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted August 6, 2021 Author Share Posted August 6, 2021 Thanks David, Message me with a price and your bank details. My dash vent is usable but one of the four dividing splines is missing. Link to comment Share on other sites More sharing options...
®evo03 Posted August 7, 2021 Share Posted August 7, 2021 Heating ducts, wonder how many miles we all have of this stuff if we joined it all together. Any other use for it? Brake ducts, dam air for carbs! Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted August 7, 2021 Author Share Posted August 7, 2021 1 hour ago, ®evo03 said: Heating ducts, wonder how many miles we all have of this stuff if we joined it all together. Any other use for it? Brake ducts, dam air for carbs! I only have 0.000124miles of usable ducting - that’s why I need some more. 😁 Link to comment Share on other sites More sharing options...
mepbowles Posted August 11, 2021 Share Posted August 11, 2021 On 05/08/2021 at 16:24, Jonathan Pounsett said: I can’t believe I’ve lost so many parts! The latest things I’ve mislaid and need to replace; ~ Fuel tank filler neck grommet. ~ Flexible heating & ventilating ducts. 🤞 I ordered a rubber filler grommet from Edelschmeide for my four door but I wasn't sure if it was even something that they came with. 1 Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted August 24, 2021 Author Share Posted August 24, 2021 Thanks @mantasrme. Ventilation ducting all up together now and fuel tank grommet cleaned up nicely as you said. I found the original within half an hour of fitting the one you sent me. 🙄 1 Link to comment Share on other sites More sharing options...
Jessopia74 Posted August 25, 2021 Share Posted August 25, 2021 What putting you at a dead stop currently mate? 1 Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted August 25, 2021 Author Share Posted August 25, 2021 7 hours ago, Jessopia74 said: What putting you at a dead stop currently mate? I don’t want to fit door glass and winders until I have door checks - better access. Roof lining needs to be in before front and back windscreens. Easier to fit dashboard top before front windscreen. Carpet needs to be in before seats. ………. and similar issues under the bonnet but these are V8 related. Link to comment Share on other sites More sharing options...
Jessopia74 Posted August 26, 2021 Share Posted August 26, 2021 If it's an absolute show stopper for you I could help with the Carpet from my black coupe as that at least a coupe of years away from starting. can't with other bits as I still don't have anything collected . 1 1 Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted August 26, 2021 Author Share Posted August 26, 2021 2 hours ago, Jessopia74 said: If it's an absolute show stopper for you I could help with the Carpet from my black coupe as that at least a coupe of years away from starting. can't with other bits as I still don't have anything collected . That’s a very generous offer @Jessopia74especially as you will actually need it yourself - even if that is a few years down the line. @MrCarlosmay have a dark tan carpet that would suit my car but if that doesn’t work out I’ll be back in touch. 1 Link to comment Share on other sites More sharing options...
