BEEDZ Posted October 2, 2021 Share Posted October 2, 2021 Needed for a 2.0 on 38 dgas Something like an OP 214 or OP 224 Some advice or links for good standard crank bearings, std piston rings set, timing chain and tensioners oil pump gears, 2.0 Gasket Re-build set Tia Link to comment Share on other sites More sharing options...
611 Posted October 2, 2021 Share Posted October 2, 2021 These guys are good for the bearings etc.. https://www.cs-parts.de/index.php?k=67 and i have a brand new timing chain and the chain tensioning guide if you interested. You will struggle for the oil pump gears as any new ones will be super expensive unless you are very lucky to find someone who has a set that they don't realise what they are for 🙂 Also get the rubber rocker cover and sump gaskets. So much better than the cork ones. I probably have the part numbers somewhere, will see if i can look them out. 1 Link to comment Share on other sites More sharing options...
BEEDZ Posted October 2, 2021 Author Share Posted October 2, 2021 7 minutes ago, 611 said: These guys are good for the bearings etc.. https://www.cs-parts.de/index.php?k=67 and i have a brand new timing chain and the chain tensioning guide if you interested. You will struggle for the oil pump gears as any new ones will be super expensive unless you are very lucky to find someone who has a set that they don't realise what they are for 🙂 Also get the rubber rocker cover and sump gaskets. So much better than the cork ones. I probably have the part numbers somewhere, will see if i can look them out. Thanks 611 Interested I’m timing chain and guides Info appreciated Link to comment Share on other sites More sharing options...
611 Posted October 2, 2021 Share Posted October 2, 2021 31 minutes ago, BEEDZ said: Thanks 611 Interested I’m timing chain and guides Info appreciated No problem. I will dig the chain and guides out tomorrow and get some pics for you. Andy Link to comment Share on other sites More sharing options...
611 Posted October 4, 2021 Share Posted October 4, 2021 Hi Mate Here is the chain and guides. I think i might have the long guide as well but need to get up in the loft and have a rummage which i can do tomorrow. All new parts, the chain packet has been opened as i need to check it against an original GM chain to make sure it was the same length. Guides are remade in Germany i think. Andy Link to comment Share on other sites More sharing options...
