cam.in.head Posted May 9, 2022 Share Posted May 9, 2022 it should have the washer yes but there should also be a tension spring on the pedal to "pull" the pedal down and take up the slack. originally this is "snail type" wound spring that can break ( mine did) they are refffered to as a constant contact clutch release bearing rather than some cars which have some slack .the haynes book shows a return spring fitted to early models .( cavalier mk1 book page 83)so this is easy enough to add rather than the other type of spring 1 Quote Link to comment Share on other sites More sharing options...
