Manta B Ventilation Fan
Jonathan Pounsett
You may be aware but just in case you don’t find one
https://mantaclub.org/forums/topic/43816-heater-motor-bearing-replacement/
is a great write up of repair/refurb.
I ordered the recommended bearings yesterday as mine failed the other day but thought it was just a slightly dodgy plug/socket. On Saturday I discovered that the wires had become brittle/broken on the blower side of the 3 pin plug so will need to source that too.
Note that the black is constant +12v & the switch inside grounds the resistor or the motor.
  • Thanks 1
Thanks to @Exclusive Opel’s tutorial I now have a fully functioning fan. Thanks to to @Trookerfor pointing me in the right direction.
Knowing the tabs are likely to break made me extra cautious but I did manage to gently pry them open without any damage. I cleaned up this bearing without removing it using a rolled up piece of fine wet and dry.
I pressed the other bearings out through the retaining spring clip and then levered out the clip through the spindle hole. It was probably possible to clean this bearing in-situ too - but it’s out now.
Retaining clip was reused, pressed into place with a suitably sized socket.
Whilst it was all apart I re-sprayed the casing and cleaned up the armature and bearing surfaces.
Finally lightly oiled and reassembled with a new retaining washer.
Ingredients; spray paint and a single retaining washer.
Time taken; 1 hour.
  • Like 3
  • Thanks 1
