RetroRob Posted March 12 Share Posted March 12 Need help on buying a new temperature sensor, does anyone know the part number or know who sells them in uk . cheers Rob Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted March 13 Share Posted March 13 Is it the one for gauge or the injection cold sensor 1 Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted March 13 Share Posted March 13 as mentioned .....which one. if its the dash guage one then dont be suprised if if the new one makes the guage read ever so slightly different to before as different makes tend to vary . if its the injection one and weretalking standard 2 litre system then make sure that it is the single element type. ( bosch 0280130026)this type has a resistance through its 2 terminals but not to earth whereas the one fitted to 2.2, 2,5,3.0 is a double element type.both terminals have a resistance through to earth. (0280130032) 1 Quote Link to comment Share on other sites More sharing options...
Trooker Posted March 13 Share Posted March 13 If the issue is that your dashboard gauge is reading high or not at all, your fuel gauge will do similar as the problem is most likely the dashboard mounted 10V regulator for those 2 instruments. 1 Quote Link to comment Share on other sites More sharing options...
