hoobby Posted April 23, 2022 Share Posted April 23, 2022 Sorry not a manta replaced rear brake lines from abs unit all the way to calipers on a MK3 golf but getting what seems an unrealistic amount of air coming out so far used nearly 2 liters of fluid air comes in big bursts then clear of bubbles for a while and repeats seems never ending can someone confirm there is no way air can be drawn in using a pressure bleeder? and the bubbles are definitely air in the system not air drawn in. Quote Link to comment Share on other sites More sharing options...
GTEPETE Posted April 23, 2022 Share Posted April 23, 2022 I also use a pressurised brake bleeder and always put silicon grease around the open brake nipple to prevent air escaping/entering past the threads. Before using the brake bleeder I use gravity to fill the pipes with fluid, then attach the bleeder...If any of the pipe unions are not tight, you will see a leak....ps I had a lovely MK3 VR6, just lowered it, put on plain steel wheels and 1.4 Badges....even some armed response officers were impressed when I overtook their unmarked 2.8 Vectra at over 125mph.... 2 2 Quote Link to comment Share on other sites More sharing options...
hoobby Posted April 23, 2022 Author Share Posted April 23, 2022 Cheers Pete found out can create a syphoning effect with pressure on the bleed nipple thread just assumed it would leak fluid out now sorted 1 Quote Link to comment Share on other sites More sharing options...
1200bandit Posted April 23, 2022 Share Posted April 23, 2022 you can reverse bleed the system with a syringe Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted April 23, 2022 Share Posted April 23, 2022 We use a vacuum bleeder now down the garage, far better Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted April 24, 2022 Share Posted April 24, 2022 i also use a vacuum bleeder. made from an old fridge motor and sucks on the nipple to remove fluid. works perfect,only 1 person and cant let any air backwards into the system. 2 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted April 24, 2022 Share Posted April 24, 2022 59 minutes ago, cam.in.head said: i also use a vacuum bleeder. made from an old fridge motor and sucks on the nipple to remove fluid. works perfect,only 1 person and cant let any air backwards into the system. Cracking idea that 👍 Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted April 25, 2022 Share Posted April 25, 2022 i have the suction side of the motor/ compressor fed into a large glass jar with no hose on it.then a second hose into the jar down to the bottom.this is the hose that you put on the bleed nipple. the suction then creates suction on the nipple to draw the fluid out.ive also fitted a small t piece and little tap on the suction side from the motor to make it variable. so you can get a bit of control over it, basically you end up with a proper usefull suction tool to drain things as well such as power steering resevoirs,brake fluid resevoir,oil spills etc. Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted April 25, 2022 Share Posted April 25, 2022 We use something similar to this https://www.sealey.co.uk/product/5637204666/1l-pneumatic-vacuum-brake-bleeder Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted April 25, 2022 Share Posted April 25, 2022 that will work in a similar fashion yes.pump up the vacuum to draw the fluid out. these ideas are much better and give better results than the old '2 man manual method' Quote Link to comment Share on other sites More sharing options...
hoobby Posted April 30, 2022 Author Share Posted April 30, 2022 Couldn't get air out of the abs pump took it to a garage to activate the pump to be told car was made in the wrong millennium "too old" I think the actual words were not so sure if he meant me or the car. 2 Quote Link to comment Share on other sites More sharing options...
GTEPETE Posted May 2, 2022 Share Posted May 2, 2022 On 25/04/2022 at 17:24, cam.in.head said: that will work in a similar fashion yes.pump up the vacuum to draw the fluid out. these ideas are much better and give better results than the old '2 man manual method' Or one man and his mum or wife/girlfriend....when they pump the clutch pedal! or you forget to ask them to release the brake pedal, and they say after 5 minutes "Can I release it now, my leg is killing me!" 2 Quote Link to comment Share on other sites More sharing options...
