Malcolm Cliff Posted April 30, 2022 Share Posted April 30, 2022 The red light came on,bought a new alternator,no change,also when ignition turned on no lights come on until engine is started. Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted May 1, 2022 Share Posted May 1, 2022 itsounds like either a problem with the ignition switch or where it plugs into the connector half way down the steering column. or a dashboard /instrument earthing issue. doesnt sound like anything to do with the actual alternator itself.(or even the other one !) find out why the dashboard isnt going live first(oil lamp,ign lamp,handbrake lamp,fuelguage,temp guage) should all come on. Quote Link to comment Share on other sites More sharing options...
Malcolm Cliff Posted May 1, 2022 Author Share Posted May 1, 2022 Thanks,been on a rally all day so will look in the morning. Quote Link to comment Share on other sites More sharing options...
ANDY ABBOTT Posted May 1, 2022 Share Posted May 1, 2022 Do you have your alternator earthed ? Quote Link to comment Share on other sites More sharing options...
Malcolm Cliff Posted May 3, 2022 Author Share Posted May 3, 2022 Yes,took dash out and found nothing wrong,put it all back and all working now. Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted May 3, 2022 Share Posted May 3, 2022 ah thats good. suggests it was a bad connection on the dash plug then. alternator will no doubt be working fine now as well . if it happens again make sure all pins are a good fit in the socket and pushed right in. Quote Link to comment Share on other sites More sharing options...
®evo03 Posted May 4, 2022 Share Posted May 4, 2022 Can you test alternator is charging the battery. Quote Link to comment Share on other sites More sharing options...
611 Posted May 4, 2022 Share Posted May 4, 2022 My A series did that and it was the white plastic plug on the back of the dash, i made sure all terminals fitted the pins tight and problem solved! Quote Link to comment Share on other sites More sharing options...
