plumster Posted July 3, 2022 Share Posted July 3, 2022 Hi folks, where does the handbrake light switch live, mine flashes on & off when the handbrake is clearly off, so I'm assuming the switch is sticking or dying. But, where does it live? Thankeee.. Quote Link to comment Share on other sites More sharing options...
H-400 Posted July 3, 2022 Share Posted July 3, 2022 (edited) That light is also connected with the mainbrake fluid reservoir, please do check the level of the brakefluid. Had a look in the partscatalogue, looks like the switch is fitted into the handbrake lever, never had issues with that switch in all those years, but there is always a first time... Edited July 3, 2022 by H-400 1 Quote Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted July 3, 2022 Share Posted July 3, 2022 In addition to @H-400 ‘s advice also check the sensor on the clutch pedal as for some bizarre reason, it’s connected into the same warning light. If it turns out it is a problem with the handbrake switch I’ve got a spare that I bought from @Paul Barrettrecently but didn’t use. 1 Quote Link to comment Share on other sites More sharing options...
plumster Posted July 3, 2022 Author Share Posted July 3, 2022 Cheers folks,will check that. Quote Link to comment Share on other sites More sharing options...
