mcintbg Posted August 15, 2022 Share Posted August 15, 2022 Need a new sump gasket for the A. Any idea where to buy one ? 1 Link to comment Share on other sites More sharing options...
Jessopia74 Posted August 15, 2022 Share Posted August 15, 2022 Is it multi piece type like AsconaA ? https://www.ebay.co.uk/itm/402017482100 Link to comment Share on other sites More sharing options...
mcintbg Posted August 15, 2022 Author Share Posted August 15, 2022 There was not one on it just gunge.... I looked at this one https://www.ebay.co.uk/itm/143652770562 Link to comment Share on other sites More sharing options...
611 Posted August 15, 2022 Share Posted August 15, 2022 8 minutes ago, mcintbg said: There was not one on it just gunge.... I looked at this one https://www.ebay.co.uk/itm/143652770562 Original was cork 2 piece but the rubber one is sooooo much better. i run the rubber on one the sump and the rocker and had no leaks since fitting them 🙂 1 Link to comment Share on other sites More sharing options...
mcintbg Posted August 15, 2022 Author Share Posted August 15, 2022 6 minutes ago, 611 said: Original was cork 2 piece but the rubber one is sooooo much better. i run the rubber on one the sump and the rocker and had no leaks since fitting them 🙂 Looks so much simpler than the 4 part one, £35 mind not a cheap bit of kit. £35 + £19 postage ! Link to comment Share on other sites More sharing options...
Sutty2006 Posted August 15, 2022 Share Posted August 15, 2022 Fairly certain I’ve got spare sump gaskets I’ve ordered for my B series if you want one from one of us 👍 Link to comment Share on other sites More sharing options...
611 Posted August 15, 2022 Share Posted August 15, 2022 2 hours ago, mcintbg said: Looks so much simpler than the 4 part one, £35 mind not a cheap bit of kit. £35 + £19 postage ! Ley me have a look and see where i got mine from as im sure it wasn't that expensive :-) Link to comment Share on other sites More sharing options...
mcintbg Posted August 15, 2022 Author Share Posted August 15, 2022 Thx ! Link to comment Share on other sites More sharing options...
mcintbg Posted August 16, 2022 Author Share Posted August 16, 2022 20 hours ago, Sutty2006 said: Fairly certain I’ve got spare sump gaskets I’ve ordered for my B series if you want one from one of us 👍 Yes please, what did you use with the gasket ? Link to comment Share on other sites More sharing options...
Sutty2006 Posted August 16, 2022 Share Posted August 16, 2022 5 hours ago, mcintbg said: Yes please, what did you use with the gasket ? Nothing. I just fitted them correctly and didn’t over tighten the bolts. Sometimes over tightening them can squeeze the gasket too thin and cause it to leak. I’ll hunt it out and get picture for you Link to comment Share on other sites More sharing options...
GTEPETE Posted August 16, 2022 Share Posted August 16, 2022 What I do when fitting cork gaskets is use silicone to stick the gasket to the sump first, line it up with the bolt holes. Leave it over night to set, then you know gasket will not move when you fit it up the the engine, with more silicone... 1 Link to comment Share on other sites More sharing options...
rutts Posted August 17, 2022 Share Posted August 17, 2022 (edited) Just use wellseal on any gasket you use best stuff on the market. Never had an leaks using this stuff for over twenty years, even head gaskets get some. Does what it says. I use a paint brush to apply. Edited August 17, 2022 by rutts Additional info Link to comment Share on other sites More sharing options...
Jessopia74 Posted August 18, 2022 Share Posted August 18, 2022 You could use sikaflex, but good luck getting it off again 😀 1 Link to comment Share on other sites More sharing options...
H-400 Posted August 18, 2022 Share Posted August 18, 2022 About the sump gasket set, in Belgium we can order all the most important gakets for the CIH at our local car-parts shop. Is that not possible in the UK? Link to comment Share on other sites More sharing options...
®evo03 Posted August 18, 2022 Share Posted August 18, 2022 In my area almost all old school parts shops are gone....but we have helfords? 1 Link to comment Share on other sites More sharing options...
Sutty2006 Posted August 19, 2022 Share Posted August 19, 2022 On 18/08/2022 at 14:41, H-400 said: About the sump gasket set, in Belgium we can order all the most important gakets for the CIH at our local car-parts shop. Is that not possible in the UK? Not a chance. we have two “old school” auto shops in Stoke. One is on reduced hours and is hardly open. The other hasn’t stocked old Vauxhall/Opel stuff for years. Ok, I got a thermostat from one the other day, but it was a generic stat with gaskets which were for something else. But tell them you want an ABS sensor or a headlight for a 1993 Carlton and they run a mile. halfords are pretty useless. But euro car parts did surprise me a few weeks ago. I got 2x oil filters and 2x fuel filters for 2.2 CIH Carlton for £20. Bosch items too, Bargain! 4 Link to comment Share on other sites More sharing options...
Jessopia74 Posted August 21, 2022 Share Posted August 21, 2022 On 18/08/2022 at 19:23, ®evo03 said: In my area almost all old school parts shops are gone....but we have helfords? Same story pretty much everywhere now. Even the little small independent shops don’t actually stock much, they just get it for you later today/tomorrow from the usual large factors anyway 1 Link to comment Share on other sites More sharing options...
