Rick-Manta Posted November 14, 2022 Share Posted November 14, 2022 Howdy partners! I'm looking to sell my MK1 Cav saloon as I potentially have another Manta (number 14) and it's going to need the garage space. I bought this off Carl (MrCarlos) a few years back and it has been a brilliant car that I even used as my daily driver for about 8 months and did the London-Brighton run about 5 months ago. Being tax and MOT exempt, it only cost me classic car insurance and fuel to run, so is surprisingly cost effective to have on the road. Even though it's a 4-door saloon, it does turn heads; sometimes people confuse it for an Ascona, but in most cases they're looking at its "rat" or patina look, as most upper facing panels have a light but all over coating of rust due to how it was stored for many years. Carl supplied the car to me with an MOT and there are no structural issues and only bits of patchwork welding on the underside, rear of the sills and front valance, with new brakes and a rather low spring and shock set. I upgraded the rostyles with a set of Ascona and Manta SR ATS Classic 13" alloys and have new Nangkang 205mm wide tyres, although most of the work I've done was on the engine, that already had a new camshaft and subsequent head skim and gasket to fit. I replaced the points, distributor cap, rotor, coil and plugs with Bosch parts and have the KV85 red Magnecor HT leads. I have fitted a brand new Weber DGV carb, new water pump, fuel pump, upgraded the radiator with a alloy one and found some new red silicone hoses to compliment it. I have an early B SR steering wheel too, that I currently don't have a horn centre for, but will endeavour to find one prior to sale. There's also a fair bit of history with it, albeit not complete, with a couple of 70s invoices and early service stamps. However it does have all its tax discs and MOTs, as well as all the recent years servicing and invoices, original manual and books. It's had an oil change each year I had it and obviously new coolant with the new rad and pump. A previous owner has put a bit of pipe in the head as an oil level raiser to protect the new camshaft. I have a chrome GTE rocker cover with a pipe to vent to atmosphere, as if you connect it to the inlet, it'll smoke on start up--this isn't valves or piston rings, it's the higher oil level being drawn through the breather system. I did plan to fit a catch tank, so you may want to consider one. Work to do wise, obviously the car looks inherently tatty and would not really be worth the cost of the extensive prep work required prior to a respray. You could possibly do this yourself, but I'd rather not raise expectations. The car is reliable and drives, but a couple of times the fuses have gotten hot and melted a small part of the box, so there are improvements to be made to the wiring. I think it's related to the heater fan, as it works intermittently, so I keep the battery disconnected when in storage and have a removed a few of the non-essential fuses. The starter, alternator and distributor electrics all function fine. By the end of the Brighton run, the clutch did start to make a whirr noise when it was engaged, that I thought might be the thrust/release bearing, however it seems to have gone away now and might have just been the stop-start nature at certain points at the event. The car is located in Witney, Oxfordshire. I live just outside Witney, but can liase with a transporter guy if you're too far to collect. I've advertised it elsewhere for £4k, but to club and forum members I'd be willing to take a lot less than that, knowing it's not going to some yob or "drift" enthusiast. You can see videos of the car being driven and worked on, on Youtube: @boilerhousegarage and there's a few pictures on my Facebook advert below. Thanks.. https://www.facebook.com/commerce/listing/469258588408080/?media_id=0&ref=share_attachment 2 Quote Link to comment Share on other sites More sharing options...
Rick-Manta Posted January 29, 2023 Author Share Posted January 29, 2023 Due to a few time-wasters and a pending Manta arrival, no sensible offer will be refused on the Cav prior to my last resort of eBay. Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted January 29, 2023 Share Posted January 29, 2023 Got any pictures you can put up? Only asking as that link doesn’t work on my facebookless phone 🤣🤣 4 Quote Link to comment Share on other sites More sharing options...
Trooker Posted January 29, 2023 Share Posted January 29, 2023 The original link is broken. 1 Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted January 29, 2023 Share Posted January 29, 2023 20 minutes ago, Trooker said: The original link is broken. And that lol Quote Link to comment Share on other sites More sharing options...
Rick-Manta Posted January 29, 2023 Author Share Posted January 29, 2023 Oh, that didn't work! If you skip to 9:00 in this video, you can see a lot of the car for now.. However, it's got a front splitter/lip spoiler not shown here. Also a good look at the engine bay here.. Quote Link to comment Share on other sites More sharing options...
Rick-Manta Posted February 16, 2023 Author Share Posted February 16, 2023 The Cav's not getting much love and thanks largely to a recent eviction notice from my garage, I now have two classics I don't have a home for. Anyone need any of the Manta bits that are on the Cavalier? Some nice chrome bumpers and low mileage engine. Parting it out isn't really a route I wanted to go down, but sadly in 1 months time I won't have a choice--plus I could do with its headlamps! Quote Link to comment Share on other sites More sharing options...
Jonathan Pounsett Posted February 16, 2023 Share Posted February 16, 2023 11 minutes ago, Rick-Manta said: The Cav's not getting much love and thanks largely to a recent eviction notice from my garage, I now have two classics I don't have a home for. Anyone need any of the Manta bits that are on the Cavalier? Some nice chrome bumpers and low mileage engine. Parting it out isn't really a route I wanted to go down, but sadly in 1 months time I won't have a choice--plus I could do with its headlamps! Is it worth selling the Cavalier as a going concern rather than breaking it? 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted February 16, 2023 Share Posted February 16, 2023 16 minutes ago, Rick-Manta said: The Cav's not getting much love and thanks largely to a recent eviction notice from my garage, I now have two classics I don't have a home for. Anyone need any of the Manta bits that are on the Cavalier? Some nice chrome bumpers and low mileage engine. Parting it out isn't really a route I wanted to go down, but sadly in 1 months time I won't have a choice--plus I could do with its headlamps! Take what you want off it and get it listed on FB or EBay, someone will buy it for sure 1 Quote Link to comment Share on other sites More sharing options...
TheRealExile Posted February 16, 2023 Share Posted February 16, 2023 Be a real shame to break but as Jess says someone will buy it even if you take the Manta bits off. No room at the Inn sadly as got one to move on, would have had some fun and I'd hope someone else thinks the same. 2 Quote Link to comment Share on other sites More sharing options...
Rick-Manta Posted February 17, 2023 Author Share Posted February 17, 2023 1 hour ago, Jonathan Pounsett said: Is it worth selling the Cavalier as a going concern rather than breaking it? Well, that's what I was doing and it has 200 watchers on eBay, but no offers or takers. It's been advertised elsewhere since November, so must be too bohemian and limited appeal with the rusty look. 1 Quote Link to comment Share on other sites More sharing options...
MrCarlos Posted February 17, 2023 Share Posted February 17, 2023 Ill buy it back for the right money rick 🙂 Please dont break it ! 4 Quote Link to comment Share on other sites More sharing options...
Rick-Manta Posted February 19, 2023 Author Share Posted February 19, 2023 Since mentioning the potential to break it, I did recently get a couple of offers at the wrong money. At best it looks as though it's going to be sold as a project with some missing parts, which might actually suit it better than being presented as a ready-to-drive running car. 2 Quote Link to comment Share on other sites More sharing options...
Slowmotion Posted March 26, 2023 Share Posted March 26, 2023 @Rick-MantaDid you find a home for this? I'm just around the corner in the Bartons...! Nice to see some members so close 1 Quote Link to comment Share on other sites More sharing options...
Rick-Manta Posted March 29, 2023 Author Share Posted March 29, 2023 On 26/03/2023 at 21:49, Slowmotion said: @Rick-MantaDid you find a home for this? I'm just around the corner in the Bartons...! Nice to see some members so close Hi Jake. Yes, it went recently; back to the guy I bought it from, so I'm glad the shell survived as a whole car. I sold most of the engine components and some trim, but thankfully the main body of the car stayed together and will hopefully see some new paint, as I learned the hard way, the rat/rust look basically makes the car unsellable--at least complete. I've got a Manta too, which I may be getting a garage for in Woodstock. Not exactly local, but there's just nothing available near me. There are a few guys in the Banbury and Bloxham area too. Thanks. 1 Quote Link to comment Share on other sites More sharing options...
®evo03 Posted March 29, 2023 Share Posted March 29, 2023 Just needs a Saab 2.3 now, proper rat, sleeper. 1 Quote Link to comment Share on other sites More sharing options...
