Bosch L-Jetronic manual
Great find. Originals don’t pop up in good conditions very often.
A lot of the document is already on the net, as it’s generic across many different manufacturers of the era. But the L-Jetronic was only fitted to the very early GT/E and there is a difference to what was fitted to the later GTE cars, mostly what you will notice immediately is the external fuel pump relay. The L-Jetronic had this pump trigger from the AFM.  But there are quite a few other differences.
The Haynes Manual has a pretty good wiring diagram for the LE.
if you want to print your own copy, https://e28goodies.com/wp-content/uploads/2016/11/Bosch-L-Jetronic-Injection-Technical-instructions.pdf
