Manta '84 Rebuild "The Sive"
john man
A bit scabby, but not bad!
No sunroof to contend with, so that is a huge positive. Obviously was robbed of its gearbox/engine for an XE conversion parts in the past. Issue is getting hold of them now too.
looking forwards to seeing your progress. 👍😎😎
  • Thanks 1
So as you can see the first 18" at the front, is main concern and would say the most expensive with the cost of front panels from what I can see online, wow.
So if anyone knows of a front panel, give me a DM. If I could get a cut of a front that would make mylife a lot easier.
Until the next update.
All those panels are available now. Hand made, but guy does craft them .
Swans ofc, you better strip outer skin first to check inners before you commit to buying anything. But again, available albeit from Continent for those.
Edited by Jessopia74
Succes with the restoration, the advantage of having no engine/gearbox is you can fit whatever you want. Don't have to be Manta, the Opel Omega is a possibility. Or any rwd car 😁
  • Like 3
