akis-driver Posted May 26, 2010 Share Posted May 26, 2010 Hello guys im going to replace my front brake discs and i thought about replacing the front wheel bearings since the hub has to come out.Ive heard that you can regrease the existing ones but since the cost of new bearings is not high i might as well replace them.Is there anything i need to pay special attention to or a fairly straighforward job?Any tips that would make my life easier? Quote Link to comment Share on other sites More sharing options...
lamchop77 Posted May 26, 2010 Share Posted May 26, 2010 Hello guys im going to replace my front brake discs and i thought about replacing the front wheel bearings since the hub has to come out.Ive heard that you can regrease the existing ones but since the cost of new bearings is not high i might as well replace them.Is there anything i need to pay special attention to or a fairly straighforward job?Any tips that would make my life easier? Yes you can regrease the existing ones, just check to see if the bearing surfaces are in good condition. If there are signs of wear then replace them, easy straight forward job just make sure everything is clean when you install the new ones and that the bearing cups are straight and firmly down in position. HTH Chris Quote Link to comment Share on other sites More sharing options...
akis-driver Posted May 26, 2010 Author Share Posted May 26, 2010 Thanks a lot for the responce Chris.If its no big deal i will replace them they are cheap to buy new anyway. Quote Link to comment Share on other sites More sharing options...
