Denis K Posted December 30, 2013 Share Posted December 30, 2013 Full R1 carb kit including carbs set up for xe, original trumpets, bogg bros manifold, new carb to manifold machine cut silicon hoses, throttle and choke cables, Pipercross sausage filter with new backplate machined to directly bolt onto R1 carbs, Megajolt ecu with full loom and lead to plug into a lap top, full EDIS ignition set up including coilpack, tps, crank sensor, module and plug lead ends,new qed bottom pulley with built in trigger wheel to run EDIS crank sensor, new qed EDIS crank sensor mounting bracket, R1 fuel pump, new fuel filter and new silicone hoses and mini air filters to run the breather outlets on the carbs to to the atmosphere properly This is a complete setup and is as good an R1 carb set up as you will ever see. I dont even know am I doing the right thing by selling it as its such a good set up. If it doesnt sell i will happily keep it 700 pounds Send me a pm if interested Quote Link to comment Share on other sites More sharing options...
Denis K Posted January 5, 2014 Author Share Posted January 5, 2014 Sold... Quote Link to comment Share on other sites More sharing options...
