Endless Manta Adventure - since 2008
grii_35
Hi, as you will understand from the title, this was a complete adventure for me. Photos of all stages are available but it will take some time to edit and add them. But in general I believe these photos will give you an idea. I did all the work myself except the car bodywork and paint. Basically if I need to summarize the constructions, here are some of them;
Rollcage with ST52 STEEL DRAWING ( I had to get a welding machine to do it  )
Stainless steel gasoline tank (40 liters)
Spool differential (4140 material with heat treatment)
Electric water pump (I have been struggling to get the size of the aluminum flange required for installation  )
Acrylic rear wing windows
Fiberglass trunk lid and bonnet
Regeneration of all bushes to 90 shore PE
Making new adjustment shims to give a castor angle
Giving the camber angle by cutting and welding the front lower swings
Conversion from carburetor to injection
New aluminum fuel rail for conversion of original injectors to EV6
Megasquirt ECU ( manufactured by myself )
Adapt the timing gear to the original crankshaft
Electrical installation renewal (2 times and I think it will be 3 with this going  )
These are the things that come to mind for now. I hope it will be clearer when I edit and add all pictures.
https://goo.gl/photos/jCS9WqQ9AYWxxoak8
https://goo.gl/photos/xKeke1KegzVr7ooj9
https://goo.gl/photos/p7MSJMRbP8W1uzfR7
https://goo.gl/photos/NNerHt8BaHQSH2XMA
https://goo.gl/photos/Gyc49xyrCYXt92wL9
https://goo.gl/photos/jtwzTfYcKeJ2KcHx5
https://goo.gl/photos/j3HC9iGKoy45Mow58
https://goo.gl/photos/7e93qW8BHFVRUdVL7
https://goo.gl/photos/iTjeXGY9JJKi82787
https://goo.gl/photos/pYnDBDswTvHt6S1w5
https://goo.gl/photos/rAixTLKqwdB7Hfcj7
https://goo.gl/photos/ZCK37yeKCkYbjazJA
https://goo.gl/photos/Ye45eewvjCXQgkMz9
https://goo.gl/photos/ySYGNbbkWZTz32bJ6
https://goo.gl/photos/HgTV7UCmuiZYcQDg8
https://goo.gl/photos/sdco9mThVoEy6n796
https://goo.gl/photos/7vmbtP9cNZj22k469
https://goo.gl/photos/NRNQc6CV9iARa9VN8
https://goo.gl/photos/g9uTkp8yYW4ijxav6
  • Like 3
