curryracer Posted October 27, 2018 Share Posted October 27, 2018 I have just sold my spare uprated torque tube shaft, and had a bit of interest so I thought I'd get some more done. This is an uprated torque tube shaft from an Opel Manta A series axle. It will fit the Manta A and B, Chevette HS and Kadett Gte, Cavalier and Ascona. Basically anything Vauxhall /Opel with this style larger axle. I have taken a good, standard shaft then welded a 38mm OD, 3mm wall CDS tube at both ends. Then had it professionally balanced. With the extra tube it totally eliminates the wobble at high speed / high torque loadings that causes catastrophic failure. This modification has been proven to cope with 300bhp and 250lb/ft. It is a direct replacement for the original shaft, but it WILL NOT FIT the alloy torque tube. You will need to use a steel tube that will also help eliminate failure. I don't have any more shafts, so you would have to send me yours which I will get modified. If I can get another 3 or 4 people price will be £120 plus postage. Any questions please ask. Pics to follow. Quote Link to comment Share on other sites More sharing options...
