PhilW Posted October 14, 2009 Share Posted October 14, 2009 I need some advice on a clutch upgrade if there is one, i'm running a 190bhp Ecotec vx lump through a standard Manta gearbox/clutch/flywheel and they don't last long, is there a bigger stronger clutch i can use? thankyou in advance Phil Quote Link to comment Share on other sites More sharing options...
Devil Fish Posted October 14, 2009 Share Posted October 14, 2009 Most people who do an XE conversion use the clutch from a Calibra turbo... Quote Link to comment Share on other sites More sharing options...
lamchop77 Posted October 14, 2009 Share Posted October 14, 2009 I need some advice on a clutch upgrade if there is one, i'm running a 190bhp Ecotec vx lump through a standard Manta gearbox/clutch/flywheel and they don't last long, is there a bigger stronger clutch i can use? thankyou in advance Phil You need to use the Calibra turbo clutch that should sort it. Courtney do uprated kits which are pretty good, mate of mine has a 265bhp Corsa which has been fine for over a year with plenty off grief handled. HTH Chris Quote Link to comment Share on other sites More sharing options...
PhilW Posted October 14, 2009 Author Share Posted October 14, 2009 Cheers chaps, which thrust bearing do i use, the one from the Manta or will the Calibra one fit? Quote Link to comment Share on other sites More sharing options...
