kerplunk Posted December 19, 2009 Share Posted December 19, 2009 Hi, The auto in my A-series rev's the nuts off the engine before it changes up Quick question, are auto box's compatible between A and B series? Any notable improvements? Thanks, Lee. Quote Link to comment Share on other sites More sharing options...
Dan W Posted December 20, 2009 Share Posted December 20, 2009 Hi Lee, might be the kickdown cable that needs adjusting? Just a thought Quote Link to comment Share on other sites More sharing options...
stradacab Posted December 20, 2009 Share Posted December 20, 2009 Yeah, check cable adjustment, also check the govenor vac pipe is not split and the vac unit is good. Could be lots of things, sometimes simple. Is the fluid level right? Has to be checked hot with the engine running, that can cause slippage on change up. Filter may be blocked if fluid is right, brake bands could need adjusting. These transmissions are usually pretty reliable so it may not be as bad as you think. Quote Link to comment Share on other sites More sharing options...
kerplunk Posted December 21, 2009 Author Share Posted December 21, 2009 Ah thanks for the info, I'll have a fiddle and see if I can get it any better. It doesn't change up till about 4500 rpm, evem when when accelerating gently. I always end up screaming the engine down the road at in 30mph zones! Quote Link to comment Share on other sites More sharing options...
