garethestate Posted April 12, 2010 Share Posted April 12, 2010 Right bought this lot for my c20xe awhile back but deceided to keep the engine standard so I can concentrate on getting the car painted ect. Set of gsxr750 bodies spaced out to fit a cut down xe manifold.Blue injectors.All connected up with silicone tube.Got some short trumpets on the inlet side. Mtech v3 ecu with coil drivers.About 18months old.Had it checked out and a base map for a std xe with the bodies fitted put on it.Comes with about 6" of loom.With it having the coil drivers it`ll run with the vaux 60-2 crank sensor so no need to mess around with a trigger wheel. Easy to get another manifold made up to suit your car,the bodies can be spaced out easily.New maps are easily downloaded from the net.The v3 is megasquirt based but built my m-tech so is properly done. Price is £400.Would prefere collection but will send it with dhl if I have to. Drop me a pm with your email addy for pics as I'm too thick to be able to post them up here. Quote Link to comment Share on other sites More sharing options...
