16V Throttle Bodies
jasonpirtek
i am looking at fitting a bulkhead balance bar brake box. Has anyone fitted one with a 16v set up. I am going to put on throttle bodies but i am not sure whether there will be enough clearance to fit the bulkhead box???
Any help would be great.
Cheers
The QED direct to head throttle bodies fit a 16v with the original servo in place fit fine. (the ait cleaner is tight though)
If you look at Stradacab and devilfish's 400r project ther are some pictures of them on the car...maybe that might help you?
http://forums.mantaclub.org/topic/20218-stradacab-and-devil-fishs-400r-roadtrack-project/
i have jenvey throtthle bodies and a balance bar pedal box in my 16v track manta. the pedal box is a cab mounted one however and i bought that from TJM motorsport.
i cant say for certain if your brake assembly will fit ( it would be VERY tight if it did) but if you contacted TJM motorsport he should be able to tell you mate.
