andyth Posted July 4, 2010 Share Posted July 4, 2010 Hi, I wonder if any one can help me with this small problem. I gave my 1973 Manta A 1600 a service the other day and one of the jobs I wanted to do was check/ change the points. I brought a new set but when I went to change them they were slightly different. The new points have a wire black wire coming off and the existing dont. I have a Delco-Remy distributor I guess the points I have are for a Bosch. I've been back to my local parts shop but the only points they have listed in the book are the ones I have. Can they be altered to fit or what points do I need to be asking for. I'll probaly change to electronic ignition at some time but any help in the mean time would be much appreciated. Andy Quote Link to comment Share on other sites More sharing options...
stradacab Posted July 4, 2010 Share Posted July 4, 2010 If you press the spring off the stop you will probably find that the wire will lift off the plastic insulator and is interchangeable with the new set Quote Link to comment Share on other sites More sharing options...
andyth Posted July 4, 2010 Author Share Posted July 4, 2010 Thanks, I'll give that a try Quote Link to comment Share on other sites More sharing options...
