2.2 Rocker Cover
lepo5
SOLD SOLD SOLD, PLEASE DELETE
I have here a 2.2 rocker cover, an excellent upgrade for the standard item, and will fit all CIH engines from the manta "A" to the 2.4 frontera, as you can make out in the picture is has a bit of pitting on the top part of the cover in the middle, however a good machine shop should be able to skim the top of the cover, i have spent a good while cleaning the inside of the cover and i also removed the remains of the old cork gasket (which seemed to be welded on) and cleaned the sealing edges of the cover, im looking for £40 for the cover but will accept a SENSIBLE OFFER for it, postage will be extra, and will be 1st class recorded, however should the buyer ask for any other service, it will be at their own risk as i will not be held responsible should the item not arrive, or arrive damaged.also included (pictured )is a brand new cork gasket, the oil cap is aslo included but will need a thorough clean and a new rubber gasket for inside the cap, last time i got they were about 40p from vauxhall.
Edited by lepo5
