Replacing Ignition Barrel
xecoupe
Hi all, I got hold of another ignition barrel for my B coupe as the key was knackered and once you took the key out it took ages to jiggle it back in.
I just wanted some advice on how to replace as I have a habit of breaking things rolleyes.gif
I have removed the plastic cowling and there is a metal strap holding it to the steering column how does one remove this?
any help would be greatly received thumbsup.gif cheers Adie
you turn it to aux no 2 on the barrel and their is a sliding pin on the underside of the barrel push it in and pull the barrel out of the casing when replacing with new barrel do the same in reverse its simples m8 cheers blitzi!!
