chewy Posted July 13, 2011 Share Posted July 13, 2011 (edited) hello trying to take off the insturament pannel to sort out the eletrics does anyone know how to take off the lights pull button and the heater stalks. As i can undo the screws but not able to remove the headlight switch. thankyou http://www.visualope...nt-housing.html Edited July 13, 2011 by chewy Quote Link to comment Share on other sites More sharing options...
1900SR Posted July 13, 2011 Share Posted July 13, 2011 The heater control knobs just pull off, I usually set them all to the middle positions just to make it easier. The light switch has a little hole in it to release a catch, although on most cars this is long gone so again will just pull off. I suspect your car will still have the catch though. If you look around the black switch there is a little hole where it slides onto the metal stalk, a small screwdriver up there should release the catch and allow it to slide forwards. Quote Link to comment Share on other sites More sharing options...
chewy Posted July 13, 2011 Author Share Posted July 13, 2011 bingo thankyou Quote Link to comment Share on other sites More sharing options...
