bones Posted February 25, 2012 Share Posted February 25, 2012 I have a Manta A rear axle and it has what I would describe as a thick type gasket between the axle and the shaft clamp ( the bit that holds the shaft in) about 3mm thick. My HS axle is exactly the same as the Manta A end plate wise anyway but does not have this thick gasket fitted, I'm not sure if there should be any thin paper gaskets fitted with the thick one on the Manta A. Can anyone give me a bit of advise please? I am also doing a rear disc conversion with the VW alloy Golf callipers and have the mounting brackets from Epytec which have a thin steel plate to replace the drum plate. http://www.epytec.de...mse-Umbau-.html Quote Link to comment Share on other sites More sharing options...
