Which Springs?
Si Bobbs
Hi all,
I'm trying to identify a set of front springs for an Opel Manta but I'm not sure which model they are from.
I had a set of these springs some years ago and now I'm after another set. I know they were from a Manta but can't remember which one. When I tried to source some recently the ones I found were totally different - much bigger diameter and only a few coils.
They are actually for a 1954 Ford Zephyr 6. They fit just right and stiffen the front suspension up quite nicely.
The original Zephyr spring dimensions are - mean diameter: 105mm, number of coils: 11 number of active coils 9.75 and the free length is just over 400mm.
The Manta springs I had about the same number of coils as I remember, and of course the dimensions weren't exactly the same but were close enough.
I have a bit more info re. pressures if you need it but I think this is enough info for you to be able to identify the car that they most likely came from.
Many thanks
Simon
Thanks Tony,
That sounds like them, like I say, when I tried to get a set recently they were much bigger than that - must have been Manta B.
Okay, couple more questions:
How many coils?
What's the total length (free)?
What year Manta and what model are they for?
Thanks again.
I can find out the spring rate from spec for that vehicle but it sounds like they are the ones I had before.
Just thought I'd clarify my original post - on reading it again I guess it could be mis-understood:
I'm after some Opel Manta springs to fit to my 58 year old Zephyr not some 58 year old springs to fit to a Manta :D
Yeah, them's the ones! Thanks for checking, I appreciate it.
Just need to know what year and engine size your car is (don't know if it makes a difference?). That will pin it down for me so I can order some.
However, I'm sorry to tell you but I finally found some info on the web, believe it or not, in your forum!
It gives the spring rate too - 140lbs per inch compared to the stock Zephyr 105. A useful improvement.
I'm guessing there was no variation in spring rate between models on factory cars but I could be wrong. Once I know the model they are from I should be able to look into some aftermarket items to see if there is any more choice re. spring rate.
What I still can't fathom is that when I tried to buy some replacements recently, the springs I got said they were for Opel Ascona / Manta 1971 to '89 1.6 to 2 litre but were more like 6" diameter, just 5 coils and total length of approx 10". Surely your Manta fits in this range?
Anyway, thanks again mate, you've been a great help.
Si
Si mine is a 72 A series. They would come in the 70-75 years. After that the B series was out with a different set up. As long as you order for the A series you'll be on the right track. Where are you based? If near you could bring a strut over and we can trial fit a spring if you wanted.
Tony
That's great - nice one.
I'm in Bradford, but since I had some of these before I'm pretty confident I can get the right ones again, well, at least now that I've had a bit of help from you.
After yet more searching I did come across a supplier that quotes the spring dimensions too, which gives me more assurance.
Thanks again mate, you've been a great help. Getting spring data seems surprisingly difficult - most suppliers I have come across only state what model the springs are for, or maybe state that they will lower the car so many inches but rarely quote specific data.
All the best
Simon
Lol it still is long marston to me. Hot rod drags is still worth a sleep over too. Great atmosphere over there with bands etc. I do the pod for the fia stuff too, usually vip these days to get one day without walking lol. Well worth the money.
Tony
