16V Conversion Clutch Plate/cover, Genuine, New Luk
Retro Power
In case anybody is after one, we now keep in stock Genuine LUK clutch cover and driven plate combination for 16v conversion of manta etc to suit manta 5 speed or Omega 5 speed gearbox.
Price is £130 including vat plus £9 postage if you require delivery. This is for a brand new, NOT reconditioned, LUK OEM spec FLAT TYPE flywheel clutch cover, plus a calibra turbo driven plate, again new, not recon, LUK OEM spec parts.
This doesn't include the release bearing as this will depend on which gearbox you are using. For a manta gearbox you will need a std manta 5 speed release bearing, and for the omega you will need the stock omega cylinder and release bearing, plus a spacer to go behind the cylinder (again we supply these as a kit with the necessary bolts, if you need one)
I have a feeling that the clutch price may well go up as I think I caught my supplier unawares on price, and I'm not sure whether or not the deal will be the same next time. The more I order the more likely that is to be the case I think!!
