Calibra Turbo Crank Angles...(Also In Members Mech Area!)
Courtenay T 27
Just wondering if anyone knows how many degrees the Calibra turbo crank needs to turn from TDC until the blank toothed section reaches the crank sensor? It has 58 teeth, same as the Frontera wheel that's fitted at moment...... just need to know if the sensors mounted in the correct place before fitting the Calibra wiring loom.... :)
