Mantney Posted August 7, 2013 Share Posted August 7, 2013 (edited) Has anyone ever put inertia reel seatbelts in the rear of an A series? if so was it straightforward and what kit did you use? Any help would be appreciated. Edited August 7, 2013 by Mantney Quote Link to comment Share on other sites More sharing options...
Shug Posted August 7, 2013 Share Posted August 7, 2013 I did. Very straightforward. Was securon belts I used. I''ll need to dig out the part number tho. Quote Link to comment Share on other sites More sharing options...
Shug Posted August 7, 2013 Share Posted August 7, 2013 Securon 264. Mounting points should be there unless someone has welded over them during a repair like mine had been! Quote Link to comment Share on other sites More sharing options...
Mantney Posted August 7, 2013 Author Share Posted August 7, 2013 Securon 264. Mounting points should be there unless someone has welded over them during a repair like mine had been! Thanks Shug, i'm going to replace the rover rear seat with an original so hopefully the points will still be there. Quote Link to comment Share on other sites More sharing options...
Mantney Posted August 18, 2013 Author Share Posted August 18, 2013 Woohoo all mounts intact, shame about the hole that was lurking under the passenger seat. Quote Link to comment Share on other sites More sharing options...
Mantney Posted August 18, 2013 Author Share Posted August 18, 2013 (edited) Sometime I wish I would leave things alone Edited August 18, 2013 by Mantney Quote Link to comment Share on other sites More sharing options...
