taylorblue5 Posted September 25, 2014 Author Share Posted September 25, 2014 This week i've been building and crossing bridges with my Z20LER engine. So far I've swapped the throttle body for a cable operated one from an X20XEV, reversed the tophat and removed all parts not required. I have removed the counter balance shafts and blocked off the oil ways that feed them and cut down the tensioner mount to clear the new subframe based engine mount. The engine came without a flywheel so i had to find a suitable 6 holed one, I didn't realize that the z20let engine came without a dual mass flywheel so i ordered an x18xev one but the bolt holes are slightly off, brilliant!! Now the gearbox and transmission is sorted iv made my new wiring loom for the megasquirt system. I've had to ditch the standard coil pack system in favour of a twin coiled one from the XE as i donth think the standard one will be sufficient for wasted spark use. I'm hoping the original waterbar/oil cooler can be kept for simplicity, I'm trying to remember if a waterpipe heads round behind the engine on top of the gearbox. If it does I'm fine. Quote Link to comment Share on other sites More sharing options...
bkautos Posted December 29, 2014 Share Posted December 29, 2014 This week i've been building and crossing bridges with my Z20LER engine. So far I've swapped the throttle body for a cable operated one from an X20XEV, reversed the tophat and removed all parts not required. I have removed the counter balance shafts and blocked off the oil ways that feed them and cut down the tensioner mount to clear the new subframe based engine mount. The engine came without a flywheel so i had to find a suitable 6 holed one, I didn't realize that the z20let engine came without a dual mass flywheel so i ordered an x18xev one but the bolt holes are slightly off, brilliant!! Now the gearbox and transmission is sorted iv made my new wiring loom for the megasquirt system. I've had to ditch the standard coil pack system in favour of a twin coiled one from the XE as i donth think the standard one will be sufficient for wasted spark use. I'm hoping the original waterbar/oil cooler can be kept for simplicity, I'm trying to remember if a waterpipe heads round behind the engine on top of the gearbox. If it does I'm fine. seen your project did you manage to get megasquirt working also do u have a wiring diagram or what you used to wire it up many thanks regards Brandon Quote Link to comment Share on other sites More sharing options...
bkautos Posted December 29, 2014 Share Posted December 29, 2014 Lovely looking ascona, the only tiny thing is the chrome rear, chrome front would Look good! ye like this 1 Quote Link to comment Share on other sites More sharing options...
