hesus2003 Posted April 21, 2014 Share Posted April 21, 2014 Hi fitting a let in my manta at the moment just have a few questions I was on carbs so have carb tank fitted I've fitted a return to the tank but not sure if the 8mm outlet is big enough. I know the injection tank has a 13mm outlet so would I be better getting an injection tank or wud the outlet on carb tank be OK to go to swirl pot then bigger pipe to pump?Don't really want to fit lift pump want to keep it as simple as possible. 1 Quote Link to comment Share on other sites More sharing options...
madmantamik Posted April 21, 2014 Share Posted April 21, 2014 Hi, if it helps I ran my manta for 7 years with the standard carb tank and an injection engine . I used a T piece in between the tank and fuel pump and never had a problem. 1 Quote Link to comment Share on other sites More sharing options...
hesus2003 Posted April 21, 2014 Author Share Posted April 21, 2014 sound thanks for that Quote Link to comment Share on other sites More sharing options...
