¢ordy$hine Posted October 7, 2017 Share Posted October 7, 2017 Wondered if any club member have run up to a problem I'm facing. I bought new rear brake shoes and drums for my Manta B. Have found the last owner has rounded off one of the adjusters on the axle back plate. On research I've found to remove the rear back plate you need to pull out the drive shaft and buy new seals. I'm a little worried as the rear axle doesn't look standard as it's a LSD. Would appreciate any feed back. Cheers. Quote Link to comment Share on other sites More sharing options...
