johnboy Posted October 27, 2017 Share Posted October 27, 2017 Has any one removed the chrome trim from around the door opening, specifically the one bonded to the A post, I've had the side glass out, rubber seal off, removed all the screws and the trims however the last one is also bonded to the A post and I don't want to bend or kink it, any suggestions? Quote Link to comment Share on other sites More sharing options...
manta88 Posted October 27, 2017 Share Posted October 27, 2017 If it still has the original sealer behind it you could try warming it up and it should just pull off. Quote Link to comment Share on other sites More sharing options...
johnboy Posted October 27, 2017 Author Share Posted October 27, 2017 Thanks manta88 I'll give to a try. Quote Link to comment Share on other sites More sharing options...
johnboy Posted November 9, 2017 Author Share Posted November 9, 2017 Heated gently with a hair dryer and they loosened off nicely. 1 Quote Link to comment Share on other sites More sharing options...
