Map-master.uk. Posted August 6, 2018 Share Posted August 6, 2018 As above 3 piece spoiler paint all cracked so needs stripping before painting what's the best way to strip it without ruining the rubber thanks in advance Quote Link to comment Share on other sites More sharing options...
¢ordy$hine Posted August 29, 2018 Share Posted August 29, 2018 On 06/08/2018 at 20:15, Map-master.uk. said: As above 3 piece spoiler paint all cracked so needs stripping before painting what's the best way to strip it without ruining the rubber thanks in advance Hi there. Tricky dilemma. If I was you I would do a patch test underneath somewhere. If your lucky it may have been painted in Cellulose paint. Try some "gun wash first, it's about 90% thinner and 10% water. If the rubber talerates it but the paint won't budge try a premium thinner. It may work better if you rub down the paint with something like P180 which will creates deep enough scratches for the thinner to act. But again always do a patch test. Good luck my friend. 1 Quote Link to comment Share on other sites More sharing options...
