Jonnh Posted April 30, 2023 Share Posted April 30, 2023 Hi I’ve just replaced the valve stem oil seals so does anyone have an idea starting point for valve clearance for the solid lifters. The engine is 2.0 block 2.2 head with a high lift cam but I’ve no idea what the cam is . Looks like they have to be set with the engine running warm ? I know it’s been discussed many times but seems mostly hydraulic can’t find much on solid Thanks in advance Quote Link to comment Share on other sites More sharing options...
Moonmonkey Posted April 30, 2023 Share Posted April 30, 2023 I always used 12thou (0.3mm) on solid lifters with rally camshafts Kent cams recommend larger for all of their performance cams up to 24thou (0.61mm)for exhaust valve clearance on the full race cam. They recommend 16thou (0.41mm) on their fast road cam. Maybe start at 16 and tighten if you not happy but keep 12 as minimum 1 Quote Link to comment Share on other sites More sharing options...
Moonmonkey Posted April 30, 2023 Share Posted April 30, 2023 This is Pipers fitting info 1 Quote Link to comment Share on other sites More sharing options...
Jonnh Posted April 30, 2023 Author Share Posted April 30, 2023 (edited) Thanks moonmonkey great advice just what I needed .do I set them then run the engine then check again when the engine is still warm or is that a cold setting ? Edited April 30, 2023 by Jonnh Quote Link to comment Share on other sites More sharing options...
Moonmonkey Posted April 30, 2023 Share Posted April 30, 2023 Valve clearance should be set when the engine is at normal operating temperature. As you say I would set them cold and then recheck and adjust when the engine is warm. The Haynes manual quotes that you should do the final setting when the engine is warm and running at idle speed, so you have to make a chain guard etc. I always found this a pain in the arse and unnecessary, so I wouldn't recommend it. I used to get the engine to normal temp, then turn the engine off and set them static. It is far safer, cleaner and easier to get it right. 1 Quote Link to comment Share on other sites More sharing options...
Jonnh Posted April 30, 2023 Author Share Posted April 30, 2023 Thanks Moonmonkey that’s what I’ve done 👍 Quote Link to comment Share on other sites More sharing options...
