Michael mcinerney Posted June 10, 2023 Share Posted June 10, 2023 Decided to put old red up for sale.1979 1.6 automatic. I'm sure some of you have seen my posts on it in my projects section.every thing is good now engine runs perfect now no issues automatic gearbox perfect changes gear lovely and smoothly. There are some Bodywork bits to do. Blisters on rear arches also along one corner of rear window.floors seem solid and jacking pionts.drivers swan neck perfect. But little bit starting on passenger swan neck.also small round rust hole on left inner wing easy repair.probably could do wit respray if fussy.but very presentable as is. Wheels refurbished wit for new tyres. 1.6 engine new stem seals on valves. All valves lapped and valves seats.new head gasket fitted.head was checked all fine.new thermostat and new sensor. New plugs and leads.new filter and 20/50 oil.had engine flush and coolant flush after doing head gasket.also new kickdown cable fitted 230euro expensive bugger.new ATF oil in autobox.filter cleaned looks perfect and replaced. Car is located in galway ireland.dont know it anyone might have Interest in it in UK or how it works now after brexit. No idea how it works now. Looking for 6.350 euro for it.have never put car for sale on here before.so hope all ok 3 minutes ago, Michael mcinerney said: Decided to put old red up for sale.1979 1.6 automatic. I'm sure some of you have seen my posts on it in my projects section.every thing is good now engine runs perfect now no issues automatic gearbox perfect changes gear lovely and smoothly. There are some Bodywork bits to do. Blisters on rear arches also along one corner of rear window.floors seem solid and jacking pionts.drivers swan neck perfect. But little bit starting on passenger swan neck.also small round rust hole on left inner wing easy repair.probably could do wit respray if fussy.but very presentable as is. Wheels refurbished wit for new tyres. 1.6 engine new stem seals on valves. All valves lapped and valves seats.new head gasket fitted.head was checked all fine.new thermostat and new sensor. New plugs and leads.new filter and 20/50 oil.had engine flush and coolant flush after doing head gasket.also new kickdown cable fitted 230euro expensive bugger.new ATF oil in autobox.filter cleaned looks perfect and replaced. Car is located in galway ireland.dont know it anyone might have Interest in it in UK or how it works now after brexit. No idea how it works now. Looking for 6.350 euro for it.have never put car for sale on here before.so hope all ok Some pictures of bad pionts Quote Link to comment Share on other sites More sharing options...
