1.8 Stem Seals
Blockhead
A quick question, how involved is it to change the stem seals in a 1.8 OHC?
Only ask as my current 1.8 is a bit smokey, definately stem seals but probably rings as well- I've got some new seals but is it worth changing them (quick or easy job?) as I plan to RedTop in the nearish future.
Cheers.
Cheers.
put the redtop in if your 1.8 is piston ring failure, as it can be a big task just to put stem seals on and it wont make too much difference to it smoking.
Yeah that's what I was thinking.
It only smokes when it's been sitting in traffic for a minute or 2 and you then use the throttle or on over-run slowing down. That said all the time it smells a bit oily but there's no visible smoke.
