astra-sxi Posted August 21, 2009 Posted August 21, 2009 I bought my Manta on Sunday and it didn't come with any headunit so I was going to put one in but it looks as if the wires have been cut and I don't know which wire is which. Does anyone know or could give me a heads up please? I've got a stereo wiring loom from a MK4 Astra so if needed I could solder the wires onto that to get the HU to work Any help would be appreciated. Quote
Fasterthanyou Posted August 22, 2009 Posted August 22, 2009 The easiest way to do it is to get yourself a small electrical tester (about a fiver from any motor factors) its quite simple really, a live to power it (usually red), an earth (usually black) and if the unit has a electric ariel wire (sometimes orange) then that will need to be attached to the live(sometimes acts as a memory for radio stations and for all the settings). The tester will tell you whats live and what isnt providing the tester itself is attached to a decent earth (somewhere on the body, but not a rusty bit;)) all the rest will be speakers but you need to be a bit carefull with those as you wont know what side of the speaker the individual wire runs to and its easy to cross them and as a result the speaker wont fire properly and give little sound, I recently had to strip out all the speakers in my daily driver so I could tell what was what, it made it easier. I also tape the wires together first so I know that they are right before soldering them up. Make sure that the unit has an inline fuse so If you do make a mistake then it wont be to much of a disaster. HTH:thumbup Quote
astra-sxi Posted August 22, 2009 Author Posted August 22, 2009 Thanks for the reply bud. I've got a tester there so if I've got time later I'll give it a shot. Quote
