Roy Posted December 3, 2009 Share Posted December 3, 2009 I have a set of rear belts from a hatch but they won't work in my coupe. If you look side-on the sloped shape of the unit needs to be facing upwards in the coupe (bolt mounting hole at the top) whereas on the hatch it is fitted with the wide-flat side of the unit at the top (bolt hole at the bottom).. Also the unit keeps locking when it is turned up the other way. If someone is breaking a coupe with rear belts fitted (who wants to sell them)-condition of the belts themselves is unimportant as I can use mine. I'd like to be emailed a photo of them in position please before they are removed. Otherwise if you know you have a set from a coupe please get in contact so I can give you a ring to check they work 'the right way up' ! This is the only thing stopping me taking the car for its MOT as I don't want to have to strip out the rear again after its MOT'd. Look forward to hearing from you.... PM me or email roy dot fellingham at ntlworld dot com (adding .s and @'s where necessary) Or ring me in the evenings on 0776 297 5101 Roy Link to comment Share on other sites More sharing options...
