shooie811 Posted January 13, 2010 Share Posted January 13, 2010 i have a leak from my 5 speed it seems 2 be coming from were the propshaft gos in to in2 it. easy fix? cheers Quote Link to comment Share on other sites More sharing options...
andyc Posted January 13, 2010 Share Posted January 13, 2010 Best done on a ram but if not then get all four wheels off the deck ON AXEL STANDS. Prop shaft, 13mm Nut and Bolt at the back end, be careful of the lock tabs Prop should just then pull out of the box, careful of any oil that may leak out. Once the prop is out you'll see the oil seal which can be hooked out with a flat blade screwdriver. Tap the new seal in and reverse the taking apart Andy Quote Link to comment Share on other sites More sharing options...
shooie811 Posted January 13, 2010 Author Share Posted January 13, 2010 Best done on a ram but if not then get all four wheels off the deck ON AXEL STANDS. Prop shaft, 13mm Nut and Bolt at the back end, be careful of the lock tabs Prop should just then pull out of the box, careful of any oil that may leak out. Once the prop is out you'll see the oil seal which can be hooked out with a flat blade screwdriver. Tap the new seal in and reverse the taking apart Andy cheers mate r they easy 2 get a hold of from a local parts store and do u happen 2 know wat it is i ask 4 Quote Link to comment Share on other sites More sharing options...
mantadoc Posted January 13, 2010 Share Posted January 13, 2010 And watch which way round the spring goes when it falls out of the prop at the gearbox end. Quote Link to comment Share on other sites More sharing options...
