modgod Posted March 1, 2010 Share Posted March 1, 2010 any one got any advice on using the fuel pump from an r1 on an xe conversion using r1 carbs. a guy i work with races a grasstrack special using xe engines & says he uses the fuel pump from the bike aswell & it has the relay built in ive never heard of this before ???.. needless to say he.s trying to sell me a fuel pump Quote Link to comment Share on other sites More sharing options...
vauxsenb Posted March 1, 2010 Share Posted March 1, 2010 I have heard this being used before, with my R1's I use a redtop Facet pump which cost around £60 plus a Sytec pressure reg which was about £20 IIRC, so do the sums for yourself but I cant see why it wouldnt work, it only needs 3psi @ the carbs (much the same as Webers) HTH cheers, Colin. Quote Link to comment Share on other sites More sharing options...
stradacab Posted March 1, 2010 Share Posted March 1, 2010 Mine has the R1 pump . I think it is something to do with self regulating and not needing a tank to return so less complex. Quote Link to comment Share on other sites More sharing options...
modgod Posted March 3, 2010 Author Share Posted March 3, 2010 after further discusion with my mate he says the pumps are regulated/metred to run with the r1 carbs (3 psi) so no need to have a regulator & the relay is built in ,he said just keep the pump as close as poss to the tank & they work no probs.. Quote Link to comment Share on other sites More sharing options...
