2.0Inj Fuel Pump
gsi marc
This is going to sound really stupid to you guys but ive had a day off work and been refitting the fuel tank to my 2.0injection hatch and i could do with some help on replumbing it all in. I suspect the large feed from the sender unit is the feed which should go to the fuel pump 1st ,any help appreciated has i only posses a crap manual and have only worked on mantas with mechanical pump,,,,,,,,,,,cheers/marc
Hi Marc
From memory. large bore pipe from the tank to the pump then pump to damper valve and then the fuel filter and fuel filter to main fuel pipe
Cheers
Andy
thanks andy hoping to get it connected up tomorrow, just finished the welding work so trying to get it moving under its own steam {i meant unleaded}:thumbup
