manxmanta Posted March 31, 2010 Share Posted March 31, 2010 I have an 88 Manta GTE exclusive coupe. When the engine warms up i get a loud whistling noise which sounds like a referee's whistle. Does anyone have any idea what is causing this and how can i fix it? Quote Link to comment Share on other sites More sharing options...
mantadoc Posted March 31, 2010 Share Posted March 31, 2010 I've had that with a defective rad cap / head gasket and missing fan belt on occasion. If it doesn't do it with the fan belt off then it would be either water pump or alternator, but you should never run without fanbelt, and usually these two items aren't affected by warm up. Could be clutch release bearing (varies when foot on clutch). All those can make that kind of sound but not usually warm up related. Too vague really, have you any idea which end of the engine it even comes from? Quote Link to comment Share on other sites More sharing options...
mikemanta Posted April 1, 2010 Share Posted April 1, 2010 look round the inlet manifold see if it has become loose or the gasket may have gone causing an air leak. Quote Link to comment Share on other sites More sharing options...
ray70 Posted April 2, 2010 Share Posted April 2, 2010 look round the inlet manifold see if it has become loose or the gasket may have gone causing an air leak. also check if any small vacuum pipes have split or come away. Quote Link to comment Share on other sites More sharing options...
manxmanta Posted April 3, 2010 Author Share Posted April 3, 2010 Thanks for your advice guys, much appreciated. I'll keep you up dated. Quote Link to comment Share on other sites More sharing options...
