Shug Posted May 27, 2010 Share Posted May 27, 2010 (edited) Does anyone know, (or can run out and measure!) how thick the CIH exhaust manifold metal is, where the bolts/studs attach? (2.0 if it matters) Need to know to let fabricator know so they can make my new inlet manifold! Cheers Edited May 27, 2010 by Shug Quote Link to comment Share on other sites More sharing options...
costasa Posted May 27, 2010 Share Posted May 27, 2010 Does anyone know, (or can run out and measure!) how thick the CIH exhaust manifold metal is, where the bolts/studs attach? (2.0 if it matters) Need to know to let fabricator know so they can make my new inlet manifold! Cheers I Shug, Later i can measure in my exaust manifold, i have the old manifold where the solex is attach, and i have the new is from a kadet c i think is from a 2.0E (i bought this to put dual carbs) If you need the drawing i think that are a cad from opeltuners.. i gonna search. Costa Quote Link to comment Share on other sites More sharing options...
costasa Posted May 27, 2010 Share Posted May 27, 2010 I Shug, Just check and you can obtain from the site opeltuners the exaust manifold flange drawing http://www.opeltuners.com/ To obtain the CAD drawing go to the site, link cad drawings Choose the exaust manifold that you want click in download Now you see lots of leters and numbers, copy all (Ctrl + A ) now create a txt file, paste all in the txt. Change the extension from .txt to .dxf e.g name_of_file.dxf (dxf is a universal cad drawing format) now you can open your file in a CAD program Good luck, any question just ask Quote Link to comment Share on other sites More sharing options...
Shug Posted May 27, 2010 Author Share Posted May 27, 2010 Thanks for that, thats perfect! From next week Bogg bros will have a template to make bike carb manifolds for CIH engines Quote Link to comment Share on other sites More sharing options...
mantapaperman Posted June 28, 2010 Share Posted June 28, 2010 did you get the carbs done?. how much it set you back.. Quote Link to comment Share on other sites More sharing options...
Shug Posted June 28, 2010 Author Share Posted June 28, 2010 (edited) Manifold 170 + vat. Carbs need split on cih otherwise inlet runners would be different lengths. Edited June 28, 2010 by Shug Quote Link to comment Share on other sites More sharing options...
