welder Posted June 8, 2010 Share Posted June 8, 2010 I know an Xe will fit in a Manta but will an 1800 SEH fit? What engine mounts do I need? The starter motor looks like it may foul on the steering column and I'm not sure about the anti roll bar not hitting the sump. Its an auto shell so I don't anticipate clearance issues there. Any help/advice greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Robbie Posted June 8, 2010 Share Posted June 8, 2010 (edited) I know an Xe will fit in a Manta but will an 1800 SEH fit? What engine mounts do I need? The starter motor looks like it may foul on the steering column and I'm not sure about the anti roll bar not hitting the sump. Its an auto shell so I don't anticipate clearance issues there. Any help/advice greatly appreciated. Did gunman not fit a SEH into his manta, think he got it from Clive who had it in his car at one point, not 100% sure but i think its the same engine and there were no real issues. I would guess its the normal 1800 conversion bits used Charlie.Loads of room in there so will be handy enough to see what you need once you lower the engine down Edited June 8, 2010 by Robbie Quote Link to comment Share on other sites More sharing options...
