hales Posted August 9, 2010 Share Posted August 9, 2010 hi guys i know i posted wanted master cylinder before but now i need master cylinder and resevoir with seals its a ate 20 i believe i have pics. its off of a d reg manta exclusive coupe believed to be an ealier type master cylinder though. regards si Link to comment Share on other sites More sharing options...
paul1393 Posted August 9, 2010 Share Posted August 9, 2010 I only used this one for a few months before replacing it with a larger bore one from a Commodore. It was in perfect working order when removed. I have kept it with some fluid inside to prevent the seals drying out whilst stored. £45 including postage. Paul. Link to comment Share on other sites More sharing options...
mantadoc Posted August 9, 2010 Share Posted August 9, 2010 First off no warranty of any kind implied or given. Any size / bore / capacity issue aside the only difference I have found with swapping an older cylinder onto a newer car is that the fitment for the front right brake pipe, where connected to the master cylinder, changes from double flare to single flare or vice versa. Seeing as I make my own pipes and swapped to the brand new older style (still available from Brakes international) I would say the older requires single flare that end. Reason being, if it was the other way around, I would have just put the brake pipe tool back on and pressed it for double flare. Purely supposition as that is deduced, depending on the bends may not be possible. As always with brakes if in doubt at all consult an expert, don't take my word for anything. Link to comment Share on other sites More sharing options...
hales Posted August 10, 2010 Author Share Posted August 10, 2010 Hi Paul do you have a paypal account ? Do you have end photo where it goes into servo regards si Link to comment Share on other sites More sharing options...
paul1393 Posted August 10, 2010 Share Posted August 10, 2010 Hi Paul do you have a paypal account ? Do you have end photo where it goes into servo regards si Hope this is what your after? PM sent. Cheers, Paul. Link to comment Share on other sites More sharing options...
mrfixituk Posted September 6, 2010 Share Posted September 6, 2010 hi paul have you still got the master cylinder for sale.regards richard I only used this one for a few months before replacing it with a larger bore one from a Commodore. It was in perfect working order when removed. I have kept it with some fluid inside to prevent the seals drying out whilst stored. £45 including postage. Paul. Link to comment Share on other sites More sharing options...
paul1393 Posted September 6, 2010 Share Posted September 6, 2010 Afraid not mate it was sold. regards, Paul. Link to comment Share on other sites More sharing options...
