nosmanta Posted August 24, 2010 Share Posted August 24, 2010 Hi! If there's anyone who's got a junk G240 which I can use to adapt a ZF dogleg gearbox to the c20XE engine. I'm planning to have the bellhousing part sawed off the gearbox housing and attach an adapter plate to install the ZF. Please email me if you have one at mjjm63@yahoo.com. Cheers! Link to comment Share on other sites More sharing options...
rutts Posted August 24, 2010 Share Posted August 24, 2010 buy an automatic omega 2.0/2.5/3.0 bellhousing easy to get cheaper than a 1.8 bellhousing, just need to cut a hole for clutch fork and put a pivot bolt in it . Link to comment Share on other sites More sharing options...
nosmanta Posted August 26, 2010 Author Share Posted August 26, 2010 buy an automatic omega 2.0/2.5/3.0 bellhousing easy to get cheaper than a 1.8 bellhousing, just need to cut a hole for clutch fork and put a pivot bolt in it . Thats what I thought. Actually I saw one on flee bay but it was for an automatic. I asked the seller to inform me when they get a manual bellhousing so that I dont have to worry about the clutch fork and pivot bolt. Cheers! Link to comment Share on other sites More sharing options...
rutts Posted August 26, 2010 Share Posted August 26, 2010 the manual one is same as auto as it has a central hydrolic clutch bearing mechinism. you could convert to hydrolic clutch Link to comment Share on other sites More sharing options...
