welshwizard999 Posted October 28, 2010 Share Posted October 28, 2010 I need to find Looms/plugs for th above, i have a digi dash which has white and blue plugs on the back. I have a white astra gte plug which seems to fit perfect. Also if someone has the pinout for the above plugs that would be great. Thanks for your time Jason Link to comment Share on other sites More sharing options...
andyc Posted October 29, 2010 Share Posted October 29, 2010 The only way i think you will get these plugs will be to chop them of the main wiring loom and while you are there also get the gearbox speed sensor as this will give you a starting point to get the speedo to read corret, Andy Link to comment Share on other sites More sharing options...
