opelscott22 Posted November 13, 2010 Share Posted November 13, 2010 Im having a bit of a clearout and found a few bits to put up for sale. New Willwood Midilight calipers with greenstuff pads. With brackets and bolts to suit 2.8 struts. £300 New pair of drilled and grooved front discs to suit the calipers above. £50 Getrag manta 5 speed box to suit C20XE conversion with linkage, lever and new friction plate to suit.Comes with enough spares to build a further two boxes. £175 New 7x13 superlights from Midland wheels with 175x50x13 Yoko A539s (Ford fitment).These have been fitted to my Viva to roll it in and out of the garage, never used on the road. £300 RS2000 alloy bellhousing, had a small weld repair. Crack tested with PFD. £75 Crossflow block, been bored to +60" and needs a rebore. I also have rods, pistons and crank to go with it. £75 Crossflow Kent BCF1 cam, small amount of pitting to one lobe.Usable condition. £40 Manta Auto prop to suit XE conversion on Chevette, good condition. £50 Manta radiator, fresh recore in unused condition. £50 Escort Mk1-2 Ashley exhaust, unused new condition. £60 C20XE cam cover with no beltcover lip freshly powdercoated in red. £40 Open to offers on everything.I can post all the small bits(not the wheels, engine or the gearboxes). Im in Inverurie, somtimes down in Fife. Scott 07598238122 Quote Link to comment Share on other sites More sharing options...
upk Posted November 13, 2010 Share Posted November 13, 2010 i,ll take the rad if you are ok to send via courier. ta kev Quote Link to comment Share on other sites More sharing options...
opelscott22 Posted November 14, 2010 Author Share Posted November 14, 2010 Thanks Kev, PM replied to. Scott Quote Link to comment Share on other sites More sharing options...
