SENNA1 Posted August 25, 2011 Share Posted August 25, 2011 Hi guys! I want to make sure ,before ordering,that this is the correct rocker gasket for my Cav mk1 with a 2.0S OHC engine. http://www.ebay.com/itm/OPEL-MANTA-REKORD-NEW-ROCKER-GASKET-/250830457415?_trksid=p4340.m263&_trkparms=algo%3DSIC.OPJS%252BSI%26its%3DI%26itu%3DUA%252BUCI%26otn%3D5%26pmod%3D390340545051%252B390340545051%26po%3D%26ps%3D63%26clkid%3D2303337768140268051 If somebody is sure about the part number please let me know. Many thanks Quote Link to comment Share on other sites More sharing options...
monzta Posted August 25, 2011 Share Posted August 25, 2011 Hi guys! I want to make sure ,before ordering,that this is the correct rocker gasket for my Cav mk1 with a 2.0S OHC engine. http://www.ebay.com/...337768140268051 If somebody is sure about the part number please let me know. Many thanks Hi Well that depends. You wrote "2,0S OHC". So the question is is it a OHC engine, or is it a CIH engine ? If it is a CIH the part will fit, no prop. Does your engine look like this: (this is a CIH engine) Or this: (This is a OHC engine) If it is a CIH type engine, i can reccoment locating a alloy rocker cover for the engine. Theese are found on all 2,2 and 2,4 CIH engines, and older versions also exist from Opel GT and Kadett B 1,9 Coupé (oil cap is located on center of the cover on theese). Theese alloy rocker covers use a rubber gasket that is very durable, and almost never break or begin to leak so this is a nice little upgrade to keep your engine oil-free They are also good looking Check it out 2,2 and 2,4 rocker cover (only difference is the 2,2 is 2,4 on that engine) This is the one from the GT As they are both alloy they can be polished Quote Link to comment Share on other sites More sharing options...
SENNA1 Posted August 25, 2011 Author Share Posted August 25, 2011 Hi Well that depends. You wrote "2,0S OHC". So the question is is it a OHC engine, or is it a CIH engine ? If it is a CIH the part will fit, no prop. Does your engine look like this: (this is a CIH engine) Or this: (This is a OHC engine) If it is a CIH type engine, i can reccoment locating a alloy rocker cover for the engine. Theese are found on all 2,2 and 2,4 CIH engines, and older versions also exist from Opel GT and Kadett B 1,9 Coupé (oil cap is located on center of the cover on theese). Theese alloy rocker covers use a rubber gasket that is very durable, and almost never break or begin to leak so this is a nice little upgrade to keep your engine oil-free They are also good looking Check it out 2,2 and 2,4 rocker cover (only difference is the 2,2 is 2,4 on that engine) This is the one from the GT As they are both alloy they can be polished Wow! That's good info! Looks like it's the CIH i'm refering... So,i could buy this gasket then. Thanks for your help!! P.S. Where can i check for these polished rocker covers? Quote Link to comment Share on other sites More sharing options...
monzta Posted August 25, 2011 Share Posted August 25, 2011 Wow! That's good info! Looks like it's the CIH i'm refering... So,i could buy this gasket then. Thanks for your help!! P.S. Where can i check for these polished rocker covers? You are welcome Yup if your engine is a CIH you can use the item you have linked for. Those polished ones are available on German Ebay.de. Most of the time they are overprized, so getting hold of an original item, getting it blasted with nutshells or other soft material, and polishing it yourself can save you quite alot of dough ! .. Here´s one ready for polishing http://cgi.ebay.de/OPEL-KADETT-C-GTE-MANTA-ASCONA-GT-CIH-ALU-VENTILDECKEL-/370535596499?pt=DE_Autoteile&hash=item5645a481d3#ht_500wt_949 and here´s an original item http://cgi.ebay.de/Aluventildeckel-2-2er-Rekord-Top-Manta-Ascona-Kadett-/280725163890?pt=DE_Autoteile&hash=item415c860f72#ht_500wt_949 and here´s the opel gt one http://cgi.ebay.de/Opel-GT-Ventildeckel-Alu-/110732014054?pt=DE_Autoteile&hash=item19c82471e6#ht_500wt_949 When you search german ebay search: "opel aluventildeckel" or "manta aluventildeckel" or "opel gt ventildeckel" Happy hunting Quote Link to comment Share on other sites More sharing options...
SENNA1 Posted August 29, 2011 Author Share Posted August 29, 2011 I'll take a look. Thanks again! Quote Link to comment Share on other sites More sharing options...
